Detective Posted December 30, 2011 Report Share Posted December 30, 2011 Hello, i miss the possibility to change the Camera Model etc. It should be possible in my opinion, that i can change all classes, which can in Daminion displayed. Quote Link to comment Share on other sites More sharing options...
Murat Posted December 31, 2011 Report Share Posted December 31, 2011 This is some sort of information that stored to images by Camera device and it is read-only within Daminion UI. Daminion ships with powerful command line ExifTool utility that can be used to change camera model in your photos: exiftool -model=MYCAMERA YOURPHOTODIRECTORY Quote Link to comment Share on other sites More sharing options...
Detective Posted January 2, 2012 Author Report Share Posted January 2, 2012 Hello Murat, thank you for your information, but can you give me more explanation for exiftool. It seems, that i need more instruction tu use exiftool with daminion. Quote Link to comment Share on other sites More sharing options...
lintujuh Posted January 2, 2012 Report Share Posted January 2, 2012 Have a look at http://www.sno.phy.queensu.ca/~phil/exiftool/. There is full documentation of exiftool. Quote Link to comment Share on other sites More sharing options...
Murat Posted January 2, 2012 Report Share Posted January 2, 2012 thank you for your information, but can you give me more explanation for exiftool. It seems, that i need more instruction tu use exiftool with daminion. Create a text file somewhere and name it as "exiftool.bat". Add a line like this: "C:\Program Files\Daminion Software\Daminion\MediaProcessors\ImageProcessor\exiftool.exe" -model=MYCAMERA YOURPHOTODIRECTORY Where: - MYCAMERA is your new camera name - YOURPHOTODIRECTORY is a folder with photos needed to be processed For a more information please follow the link which Juha mentioned above. Quote Link to comment Share on other sites More sharing options...
Detective Posted January 2, 2012 Author Report Share Posted January 2, 2012 Thanks! Quote Link to comment Share on other sites More sharing options...
