dobs Posted May 25, 2015 Report Share Posted May 25, 2015 I use Capture One 8 as my editor and have come across an issue with the color label compatibility with Capture One and Daminion. The problem is that Daminion writes different xmp photoshop urgency fields than Capture one does, meaning that editing a color label in Daminion results in the incorrect or no color label in Capture One. Daminion does read the colors correctly though as it appears to read only <xmp:Label>Yellow</xmp:Label> which is good. Capture One writes urgency 7 for yellow <photoshop:Urgency>7</photoshop:Urgency> <xmp:Label>Yellow</xmp:Label> Daminion writes urgency 3 for yellow <photoshop:Urgency>3</photoshop:Urgency> <xmp:Label>Yellow</xmp:Label> I checked all the urgency mappings between the two programs Photoshop urgency xmp file created in capture one 8 none u0 red u1 orange u6 yellow u7 green u2 blue u3 pink u5 <----incorrectly set in capture one, maybe should be 4?? purple u5 <----same as pink???? bug in capture one 8?? Photoshop urgency xmp file created in daminion 1 red u1 2 yellow u3 3 green u4 4 blue u6 5 purple u7 6 orange u2 7 pink u9 8 brown u8 9 cyan u5 0 none Maybe theres a good reason why Daminion uses different urgency mappings, but if capture one settings cant be set as default maybe a capture one toggle could be set to switch it to capture one urgency writing compatibility mode.. Can this be implemented? Quote Link to comment Share on other sites More sharing options...
Murat Posted May 25, 2015 Report Share Posted May 25, 2015 We added this specific "Urgency to Color Label" mapping to provide compatibility with Nikon View/Capture NX. Probably it make sense to make an editable Urgency mapping rule. Quote Link to comment Share on other sites More sharing options...
dobs Posted May 26, 2015 Author Report Share Posted May 26, 2015 Hi Murat Thanks for the quick reply and info. Editable urgency mapping rules would certainly be a great edition to finally overcome the color label incompatibility. Daminion has superior DAM features and would be a major positive for capture one users. 1 Quote Link to comment Share on other sites More sharing options...
Framon Posted November 27, 2016 Report Share Posted November 27, 2016 Hi, My language is French, sorry for my poor English... I'm a new user of Daminion and I'm very enthusiast. I also use Capture One 9 for editing RAW files. Like dobs, I think it is a pity that the color labels are not compatible between the two softwares. For example, Photo Mechanic (software used by a friend) allows the editing of the color of each label allowing complete compatibility. In attachment, you'll find three screenshots. One from Capture One, the others from Photo Mechanic (original and after personalizing). Possible to plan this little extra tool? Thanks in advance and congratulations for the quality of your software! Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted November 28, 2016 Report Share Posted November 28, 2016 Hello Framon, Can you please add your feature request here? We need to know how many of our users require this feature before implementing it. Best regards, Daria Quote Link to comment Share on other sites More sharing options...
