JMG Posted February 6, 2015 Report Share Posted February 6, 2015 Hi, I can’t get the REST API to work. I have tested everything I can think of so now I need some help. API is enabled (at port 8090) in the server settings but when I try to call the API using some of the queries that are listed on the API-page it doesn't work. I have tested it from the computer running Daminion server. I also have tried accessing it from another computer (using both the correct server name and ip address). But I never get any response only a refused connection (“ERR_CONNECTION_REFUSEDâ€). When I check all listening ports (“netstat -a | find "LISTENING"), the port that Daminion uses (8090) for the REST API isn’t listed. What am I doing wrong? I’m running Daminion 3.4.0.1113 (Trail) on Windows Server 2003 R2 (SP2). Quote Link to comment Share on other sites More sharing options...
Murat Posted February 7, 2015 Report Share Posted February 7, 2015 Sorry for the inconvenience. REST API is broken in the current 1113 build. I can send you the test (non-public) Daminion 3.7 build on the upcoming Monday for testing purposes with the bug-fix. Quote Link to comment Share on other sites More sharing options...
JMG Posted February 7, 2015 Author Report Share Posted February 7, 2015 Sorry for the inconvenience. REST API is broken in the current 1113 build. I can send you the test (non-public) Daminion 3.7 build on the upcoming Monday for testing purposes with the bug-fix. Ok, it would probably be a good idea to publish a statement about that on the web site, e.g. on the REST API page. I have spent a couple of hours troubleshooting this! It would be great if you could send me the test build on monday! Quote Link to comment Share on other sites More sharing options...
Murat Posted February 9, 2015 Report Share Posted February 9, 2015 You are right. I've put a note that the Rest API in the current 3.4 version is broken. Will send you the test link to the Daminion Server 3.7 beta shortly. Please install it on a new PC without existing Daminion Server installation, until we'll publish it here. Quote Link to comment Share on other sites More sharing options...
kinjo Posted January 16, 2017 Report Share Posted January 16, 2017 I am Having ERR_CONNECTION_REFUSED problem in my PC Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted January 16, 2017 Report Share Posted January 16, 2017 I am Having ERR_CONNECTION_REFUSED problem in my PC Hello Kinjio124, what Daminion version do you use? regards, Daria Quote Link to comment Share on other sites More sharing options...
kinjo Posted January 17, 2017 Report Share Posted January 17, 2017 I am Having ERR_CONNECTION_REFUSED problem in my PC Here’s the mail I got recently when I get this problem again I received the same msg ERR_CONNECTION_REFUSED and was blocked from doing any searches. (But I could listen to and watch Youtube videos!) I don't know what your computer said, but I am running Google Chrome on windows 7 and above the message it said to: 1) Click on the Chrome Menu (the 2 bars in upper right hand corner of the Google Home page. 2) go to Settings > then "show advanced setting" 3) click Change proxy settings 4) click LAN Settings 5) UNclick "use a proxy server for your LAN" Was still getting ERR_CONNECTION_REFUSED Then closed all windows and programs REBOOTED PC Now, everything is fine! (REBOOTING (RESET) IS A NUISANCE, BUT IT HELPS) I hope this info helps you. http://www.deskdecode.com/err_connection_refused/ Quote Link to comment Share on other sites More sharing options...
