fhahn Posted August 30, 2014 Report Share Posted August 30, 2014 I have just started trialing Daminion Server. After adding some files, I had an Excel file added that I wanted to remove. I was able to right-click and delete the document from the catalog. Under Media Format, I now have an entry of XLS - Microsoft Excel and it shows 0 documents. I have tried to delete this but I get an error. I have hopefully attached the file to this post. Let me know of any additional needed information. Thanks. Frank Quote Link to comment Share on other sites More sharing options...
fhahn Posted August 30, 2014 Author Report Share Posted August 30, 2014 I just figured out that my attachment did not make from earlier. I have just started trialing Daminion Server. After adding some files, I had an Excel file added that I wanted to remove. I was able to right-click and delete the document from the catalog. Under Media Format, I now have an entry of XLS - Microsoft Excel and it shows 0 documents. I have tried to delete this but I get an error. I have hopefully attached the file to this post. Let me know of any additional needed information. Thanks. Frank Quote Link to comment Share on other sites More sharing options...
rene Posted August 31, 2014 Report Share Posted August 31, 2014 Hello Frank, i doubt that you will be able to remove that. Maybe you can remove it by running the optimze database command, not sure though Quote Link to comment Share on other sites More sharing options...
