Uwe Posted December 26, 2013 Report Share Posted December 26, 2013 Hello, when I change the "Creation DateTime" in the Properties Panel the Metadata "DateTime Original" in the file is adjusted. I did the same with the ExifTool but neither Rescan Folders nor Read Tags from File reads the adjusted data. Not even a restart of the client or the database helps. So it seems that Daminion doesn't use the metadata DateTime Original in theses actions. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted December 26, 2013 Report Share Posted December 26, 2013 Was the file modified date changed? Quote Link to comment Share on other sites More sharing options...
Uwe Posted December 26, 2013 Author Report Share Posted December 26, 2013 Hi Murat, yes, it is changed to the date and time of the adjustment by the ExifTool. The video (Daminion_930_DateTimeOriginal.wmv) is in my FTP folder. Regards, Uwe Update: I've removed the adjusted item from catalog. Then I imported it again by rescan folders. Also in this case the DateTime Original is not used by Daminion. What metadata date does Daminion use? I used this ExifTool command: "-EXIF:CreateDateNow I get the adjusted date and time. Conclusion: Daminion uses either the Exif Create Date or the XMP DateCreated Quote Link to comment Share on other sites More sharing options...
Murat Posted December 26, 2013 Report Share Posted December 26, 2013 Can you please send me that JPEG file? Quote Link to comment Share on other sites More sharing options...
Murat Posted December 26, 2013 Report Share Posted December 26, 2013 Will be fixed in the next Daminion update. Thanks for the assistance! Quote Link to comment Share on other sites More sharing options...
Uwe Posted December 27, 2013 Author Report Share Posted December 27, 2013 Hello Murat, thank you. It works in 932 as expected. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
