[911] I get crazy: Same problem with mutated vowels again !!!
_noel_
Today I noticed, that build 911 has again problems with mutated vowels :crazy:
Workflow: write a keyword with mutated vowels to a NEF, store the NEF and do a "read tags from file" -> keyword is duplicated: one is ok, the other is crippled.
See screenshot here, the NEF is here.
Daminion config writing metadata is here.
JPGs seem to work OK with mutated vowels.
Wasn't the problem solved a few builds before ?
Regards
Eberhard
Some details:
The error occurs first time with v910, with v909 everything is ok.
If I go back to v909 and do a "Read tags from file" with the images, which have scrumbled tags with mutated vowels, then the scrumbled tags disappear.
... so between v909 and v911 this error has creeped into Daminion.
Regards
Eberhard
realised the same problem. During my vacation I created Places with vowels and after importing them to my Server the vowels where gone
In my case the tags with vowels got duplicated after import: one tag was ok, the other was crippled.
With other tools (exiftools) the files look ok, so it' "only" a display problem within Daminion ...
  • 3 weeks later...
The problem was existed for RAW images, when tags were written directly into the RAW files itself (without sidecars). Daminion incorrectly interpreted Encoding of the XMP strings in the RAW images during the import.
The problem was fixed and a new build will be ready very soon.
