rene Posted September 30, 2013 Report Share Posted September 30, 2013 Hey Murat, today I reimported a lot of pictures who already have Picasa face tags included. First I deleted them from the catalog and than I reimported all the files, with these tags. the names havn't been imported. So I hit "read tags from file" still no names! Eventhoug I have everything correctly configured. Any thoughts? Log files via email, since the logs are severall files so I zipped them. thanks, rene! Quote Link to comment Share on other sites More sharing options...
rene Posted October 1, 2013 Author Report Share Posted October 1, 2013 So after upgrading to 886 this is still not working Quote Link to comment Share on other sites More sharing options...
Murat Posted October 1, 2013 Report Share Posted October 1, 2013 What Picasa version do you use? Did you close Picasa before invoking "Item > Read Tags from File" command? Quote Link to comment Share on other sites More sharing options...
rene Posted October 2, 2013 Author Report Share Posted October 2, 2013 Hey Murat, I use Picasa 3.8.0 (Built 117.41, 0) as in Picture 2. I tried it with Picasa open and closed. I can give you my logfiles in case there is some information inside it. Quote Link to comment Share on other sites More sharing options...
Mammut Posted October 2, 2013 Report Share Posted October 2, 2013 Murat, did you read the other Picasa topic, where we talked about that Picasa puts the face data in the MWG Regions metadata group, there are the name and coordinate tags? That way we don't need the ini file. Quote Link to comment Share on other sites More sharing options...
rene Posted October 2, 2013 Author Report Share Posted October 2, 2013 Mammut, there are two ways for picasa to store name tags. 1. in the ini-files 2. in the picture itself It needs to be stored in the ini-files with Picasa Version 3.8 or older version in order for daminion to read the tags. I mean it would be great, if Daminion would simply while importing or while rescanning read those picasa tags and than convert them to the people tag. In the end Daminion should have its own face recognition. Quote Link to comment Share on other sites More sharing options...
Mammut Posted October 3, 2013 Report Share Posted October 3, 2013 Yeah, a built-in face recognition and annotation system would be the best, but I think those features are in the far future. :) At least I'm sure it needs a lot of work to be good, I saw bad face recognition, in example in Adobe Elements Organizer. Quote Link to comment Share on other sites More sharing options...
rene Posted October 3, 2013 Author Report Share Posted October 3, 2013 @Mammut: right! @Murat: After the TV-Session the Picasa import seemed to work, but there are still a lot of problems. 1. I rescanned the folder of pictures which is already fully face tagged in Picasa, but nothing happend. So I created a new Catalog, within this catalog 1 face had been imported. after a second run another face (another person) had been imported. 2. After rescanning the whole folder again within the shared catalog no faces where recognized. Would it be possible to import all the picasa.ini files itself to read all the tags, might be faster? regards René! Quote Link to comment Share on other sites More sharing options...
rene Posted October 6, 2013 Author Report Share Posted October 6, 2013 Hey Murat, nothing changed in Version [889]. I meanwhile tried it severall times. it imports 1 face and person on a local non shared catalog, but if i perform the same action on a shared catalog no faces and names are imported. I opend daminion as an administrator regards René! Quote Link to comment Share on other sites More sharing options...
