rene Posted August 27, 2013 Report Share Posted August 27, 2013 Hey Murat, found a problem with the color tags: I renamed the color tags from the Color to 1x bestellen (order 1 times) etc. after reopening, the names are gone wild, have a look. the last colors changed: "8x bestellen" had a different color the last "1x bestellen" was something different 20x30 was the second last one Fotobuch was the last one I started to call them by the number you have to hit inorder to tag it. thanks rene Quote Link to comment Share on other sites More sharing options...
Murat Posted August 27, 2013 Report Share Posted August 27, 2013 Can you send us the backup of your database (Admin panel > File > Backup Database...) Quote Link to comment Share on other sites More sharing options...
rene Posted August 27, 2013 Author Report Share Posted August 27, 2013 done Quote Link to comment Share on other sites More sharing options...
Murat Posted August 27, 2013 Report Share Posted August 27, 2013 Thanks for the dump. The first "1x bestellen" is ended with extra space symbol. Please select the second color label so all files belong to this label was found. Then select these files and drag them to the first "1x bestellen". And then delete the second color label. Quote Link to comment Share on other sites More sharing options...
rene Posted August 28, 2013 Author Report Share Posted August 28, 2013 OK, thanks Murat Quote Link to comment Share on other sites More sharing options...
rene Posted September 2, 2013 Author Report Share Posted September 2, 2013 Hey Murat, I changed it the way you told me, but today I realized that the tags gone wild again Quote Link to comment Share on other sites More sharing options...
