860 : Right clic on GPS Tag
kalain
Hi kalain,
I've tested with shared catalog and 860 build: no problem.
But it doesn't work as you described when the scale of the map is to small and the tag appears as one tag but there are two tags. In your case: what happens when you enlarge the scale of the map. Is there a tag with 5 items or e.g. one with two and one with 3 items?
This is a feature: we display the context menu only for a single marker.
So text "show all images at this location" should be changed into "show this image at this location"
When you read "all" it is supposed to work with several selected images.
A bit strange this behavior!
On a pink tag which group several images, if you (left) clic on it you can display "All pictures from this spot".
Now, on same pink Tag, you can't display right menu with same actions!!
Mhh! not very coherent.
  • 5 weeks later...
  • 3 weeks later...
