Comment are not beeing imported
rene
Hey folks,
when I added a few Comments to pictures and let them reimport into Daminion I get the following Messages.
PicaJet.Daminion.MediaProcessing.UserCommentInfo
insead of my original Comment.
How Can I stop that, this is destroying a lot of work of mine.
thanks rene
Unfortunately I can't reproduce the issue.
- Did the problem appear with local or shared catalog?
- What Daminion version do you use?
- Can you reproduce it if the "Add Compatibility with Windows Explorer" option is unchecked?
Hey Murat,
I forgot that.
I just installed Version 825. This Problem occured on the local Version of Daminion. I came back from my vacation where I entered everything, every evening. As I complety renamed the pictures of one folder I had it removed and reimported but the commands have been replace by the text given above.
I didn't try to reproduce it, because I don't want to loose all work.
Thanks Murat.
This problem might be related to the old Daminion version usage.
To help us to check this issue (and don't loose your work) I suggest you:
1. Make a copy of your local catalog file
2. Open your catalog by Daminion 825 version.
3. Select one image with filled comments
4. Copy the comments into clipboard
5. Invoke "Item > Actions > Write Tags to File"
6. Invoke "Item > Actions > Read Tags from File"
Do you see your comments on the right panel?
7. Invoke "Item > Actions > Show All Metadata" and check whether your comment is there (make sure that the "Add Compatibility with Windows Explorer" is checked.
Let me know if your comment was retrieved from the
Hellow Murat, it seems to work now, after installing the latest version of daminion.
thanks for your help.
