Uwe Posted May 22, 2013 Report Share Posted May 22, 2013 Hello, I've copied the tags from a DNG to a JPG item (ALT-Shift-C/ALT-Shift-V). In the pop-up window I can define which tags should be copied. There are only some tags to select. The result is: a lot of Exif data are not in the JPG file. See the screenshot of DNG and JPG properties. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted May 22, 2013 Report Share Posted May 22, 2013 Copy/Paste tags are for copying editable tags only, which are mainly belonged to the Description section in the Properties panel. To move technical/image/camera related tags please use a low-level metadata handling tools like ExifTool. For example: Copy all tags from a.cr2 to a.jpg 1. exiftool −overwrite_original_in_place -TagsFromFile a.cr2 a.jpg Copy all GPS info from SOURCE.DNG to DEST.JPG 2. exiftool −overwrite_original_in_place -TagsFromFile SOURCE.DNG -gps:all DEST.JPG After that you need to invoke "Item > Read Tags from File" command for the updated image(s) Quote Link to comment Share on other sites More sharing options...
Uwe Posted May 22, 2013 Author Report Share Posted May 22, 2013 Hello Murat, thank you for the answer. I went this way to try to close the gap in the export function of Daminion (lost metadata https://daminion.net/user-forum/index.php?/topic/1132-796-lost-metadata-in-exported-files/) I'll try to find a way to move the tags from *.dng to *.jpg as mass activity. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted May 22, 2013 Report Share Posted May 22, 2013 ExifTool allows you to specify a hole folder instead of the separate files. You can even create a .bat file that will contains a few lines of a script with ExifTool. And then drag the selected folders/images to this .bat file. More info can be found on the ExifTool home page. Quote Link to comment Share on other sites More sharing options...
