Question: should Daminion write/modify EXIF DateTime?
Uwe
at present Daminion doesn't write or modify Exif DateTimeOriginal. A lot of other programs modify or use this Exif Tag e.g., to rename the file from "scan_01.tif" to "yyyymmdd_hhmmss.tif" or to sort the files by Exif date.
My question: why doesn't use Daminion this Exif Tag?
From the moment I switch with all my media files from the program XYZ to Daminion I don't have this tag in my scanned items or I have the initial value written by the camera there and all adjustments are in the IPTC/XMP data.
Should I forget this EXIF Tag?
By default, for performance reason, Daminion writes tags to XMP only (but read from EXIF/IPTC/XMP and native format specific metadata).
You can enable writing tags to EXIF/IPTC by checking an appropriate option in the program's Preferences:
"Preferences > Writing Metadata > Add Compatibility with old programs"
After that Daminion will write datetime to EXIF Original Date.
I would like to come back to this topic.
Even if you customize the preferences that no EXIF data should be written - Daminion writes the EXIF:Software tag.
From my point of view the performance to write DateTimeOriginal is not depending on the write process of EXIF data because Daminion writes EXIF data in any case.
