lintujuh Posted January 1, 2024 Report Share Posted January 1, 2024 (edited) I have a setup with laptop screen (sRGB), and Eizo ColorEdge monitor. I decided to take advantage of the larger color gamut of my monitor, and export my photos in AdobeRGB instead of sRGB. Windows shows the color profile of the laptop screen as sRGB, and the Eizo monitor as AdobeRGB. When I uploaded a test image in Daminion that has out of sRGB gamut colors, it doesn't show correctly on my secondary screen. When I go to Edit > Preferences ... > Color Management, it shows me Display Profile sRGB. If I click Customize I end to Windows display profile settings that have correct profiles for the primary and secondary screen. How can I change Daminion to use the correct display profile on my secondary screen. I have attached a test image that should show text ColorEdge when displayed on AdobeRGB profile. (EDIT: here is the link to the image, it looks like the forum does something to the image.) When I searched the forum, I noticed a similar question was raised already earlier. Edited January 2, 2024 by lintujuh Added link to the example image as the inserted image has lost the color profile. Quote Link to comment Share on other sites More sharing options...
lintujuh Posted January 1, 2024 Author Report Share Posted January 1, 2024 When I converted the png file to jpg, it works correctly. But, even when I tick in Apply Display Color Profile both preview images and display thumbnails the catalog window doesn't show the text. I tried also to update the thumbnail, but it didn't help. Also, it is confusing that the dialog box shows Display Profile as sRGB, even when it is AdobeRGB. Quote Link to comment Share on other sites More sharing options...
Oleg.Ross Posted January 12, 2024 Report Share Posted January 12, 2024 Hello, please send me an example file with an extended color range to my email. I can only see a pink rectangle. We do not support color profile settings for the second monitor. Perhaps it would be worth specifying your monitor as the first monitor and then everything will work correctly? Quote Link to comment Share on other sites More sharing options...
lintujuh Posted January 16, 2024 Author Report Share Posted January 16, 2024 It looks like the color management works also on the secondary screen, it just isn't visible in the preferences dialog. I used this test image that just shows the pink rectangle, if it is not color managed. I switched my secondary monitor to sRGB, and changed the color profile in Windows, and I could see the text the same way as I could see it on my laptop screen (screen #1) that is only sRGB. Quote Link to comment Share on other sites More sharing options...
lintujuh Posted February 13, 2024 Author Report Share Posted February 13, 2024 Quote Perhaps it would be worth specifying your monitor as the first monitor and then everything will work correctly? This is not possible as my first monitor is the laptop screen. Quote Link to comment Share on other sites More sharing options...
