Volker Posted April 19, 2020 Report Share Posted April 19, 2020 I'be got a JPG file to which I want to add a comment (screenshots 1 and 2). After saving the changes the folder is shown as empty (screenshot 3). I have to rescan the folder with F6 and the photo appears again, but without the comment I've entered before (screenshots 4 and 5). Quote Link to comment Share on other sites More sharing options...
Murat Posted April 19, 2020 Report Share Posted April 19, 2020 Mapping of the comment tag is disabled now (It was mapped to the outdated EXIF:Comment field). You can consider using Description tag instead, or create a Custom Tag. Quote Link to comment Share on other sites More sharing options...
Volker Posted April 20, 2020 Author Report Share Posted April 20, 2020 Thanks for your reply! Quote Link to comment Share on other sites More sharing options...
