kalain Posted April 13, 2019 Report Share Posted April 13, 2019 Hi, Nothing serious here, just ergonomic considerations. In tag panel you can move (drag / drop) categories as you want in the list. (Good point) Let's take an example. In General preset, I'd like to move "Saved searches" in top of the list, Ok, good. Now, if I decide to Customize "General" preset and add a categorie for example When I close this window, my personnal setting order is not anymore applied ! It would be nice to keep user"s sorting order after to customize tag presets. Regards 1 Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted November 16, 2019 Report Share Posted November 16, 2019 Hi Kalain, this issue is registered, my apologies for this. Hopefully it will be fixed by the next release Kind regards, Daria Quote Link to comment Share on other sites More sharing options...
