Minimum width map window
kalain
when displaying Map window, minimum width display is quite huge.
It would be nice to squizze a bit more width window map in order to get more space in thumbnail window in laptop screen.
Here is some suggestions :
Reduce width lists :
Choose a shorter text : (also in all other language, it's possible in French)
Reduce field search text width
In final, you could reduce width window map by 1/3, which is quite confortable in small screen as laptop.
Ok, looks like that behaviour and minimum width depends where you dock it : on red rectangle or blue rectangle.
Seems there is some odd behaviours or displays depending where you dock it.
anyway, minimum width window map is ok depending where you dock it.
... anyway, minimum width window map is ok depending where you dock it.
I found it is more convenient not dock it, but to use a free floating window for the map (as well as for Tags). When I don't need it instead of closing, I move it to the lower right corner, the most part of it being invisible. I only see the title "Map" and enough space to grab it and move to the center of the screen when I want to use the map.
