Paul Barrett Posted February 12, 2017 Report Share Posted February 12, 2017 I keep getting caught out when processing photos in the display window because some are not displayed. The problem is If you have less thumbnails in the bottom row of the thumbnail display than in the row above, the bottom row cannot be displayed when you use the PgDn button or the cursor down arrow key. The display stops at the penultimate row. The only way you can display the bottom row is to use Ctrl+End or the scroll bar. Once you have got the last row to display you can then PgDn or Cursor key down to it OK. But then, if you go back up and come down again, two rows become invisible, and this can happen even if there the number of images on the last two rows is teh s. It's very erratic in its behaviour. - Paul 1 Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted February 13, 2017 Report Share Posted February 13, 2017 Hello Paul, reproduced and registered #4516 Thank you for reporting! Best regards, Daria Quote Link to comment Share on other sites More sharing options...
