Comparing catalog and tags
lintujuh
Hi!
I experienced a disk and I believe I managed to rescue my images from backup and from the crashed disk more or less 100%. No I would like to verify the contents. I would like to
a) see if I have managed to recover all the images or if not, which are still missing
b) compare if the contents of the catalog match the tags written into the files
I didn't find any command in Daminion Client or Server that could do job. Do you have any ideas? For b) I could do select all and do write tags, but that sounds little overkill and it's also quite tedious as I have grouped images it would require expanding each group before the write opereation.
-Juha
I have grouped images it would require expanding each group before the write operation.
Only a little hint to the very last part of your question:
As I found accidentally, when you select some or all (CTL+A) pictures and press CTL+T, all groups will expand. Vice versa, if all groups are expanded and you select and you press CTL+A and CTL+T again all groups collapse.
Sorry, no idea for your main questions, though.
