Yannik Reiter Posted December 19, 2016 Report Share Posted December 19, 2016 Hi, I have an issue when i try to remove larger folders from a shared catalog. After some time I receive a timeout error which suggests to increase the timeout value in the ConnectionString. Where can I edit this ConnectionString or is there another possibility to solve this problem for me? Thanks Yannik Quote Link to comment Share on other sites More sharing options...
Daria Kotilainen Posted December 19, 2016 Report Share Posted December 19, 2016 Hi, I have an issue when i try to remove larger folders from a shared catalog. After some time I receive a timeout error which suggests to increase the timeout value in the ConnectionString. Where can I edit this ConnectionString or is there another possibility to solve this problem for me? Thanks Yannik Hello Yannik, the developer guys say this param can be changed at the code level only, sorry. How many files do the folders you're trying to delete contain? If these folders have sub-folders, can you please delete the latter ones first? Best regards, Daria Quote Link to comment Share on other sites More sharing options...
Yannik Reiter Posted December 19, 2016 Author Report Share Posted December 19, 2016 Hello Yannik, the developer guys say this param can be changed at the code level only, sorry. How many files do the folders you're trying to delete contain? If these folders have sub-folders, can you please delete the latter ones first? Best regards, Daria Hi, the folders im trying to remove have about 100.000 files in them. I already noticed that it is possible with folders containing less files, so as you suggested I'm gonna have to remove some sub-folders first. Thanks, Yannik Quote Link to comment Share on other sites More sharing options...
