Invisible line in left panel
bro999
I downloaded Daminion Standalone yesterday (v4.6(1481)). I found that the 21st line below <Filter Tags> text box in the left panel is always invisible. However I can still click the radio button to select it. It's only just cannot be seen on the screen.
Am I doing something wrong?
Hello!
It seems to be a bug, though I couldn't reproduce it at home and can't reproduce it now at my workplace.
Would it be possible to send us your catalog (.dmc file) for testing?
Daria
OK. I created another new catalog and found the same display problem. But I am unable to upload here. How can I send the file?
Thank you.
what windows version do you use?
If Windows versions matter, I give you more info as below.
I installed Dominion Standalone on 2 more computers and got below results:
Main computer (this is the computer from which I reported the display issue)
Windows version: Windows 7 Home Premium 64-bit (Chinese Traditional)
CPU: i5-4570S with integrated graphic
Display resolution: 1920x1080
Display issue: invisible lines every 21 lines, i.e. 21st, 42nd, 63rd, 84th
Second computer
CPU: i5-3470 with integrated graphic
Display resolution: 1920x1200
Display issue: invisible lines every 25 lines, i.e. 25th, 50th (different from the main computer)
Third computer
Windows version: Windows 7 Home Premium 32-bit (Chinese Traditional)
CPU: Intel Atom D525 with integrated graphic
Display resolution: 1366x768
Display issue: invisible lines every 21 lines, i.e. 21st, 42nd (same as main computer)
Hope these info are helpful.
