Uwe Posted February 5, 2016 Report Share Posted February 5, 2016 Hello, this is the result of an imported DNG file. Also a rescan folders delivers the same result. JPG works. Alredy existing DNG items (imported by previous 4.1 1280 build) in the catalog are ok. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 5, 2016 Author Report Share Posted February 5, 2016 Update: the thumbnails of "old" DNG are ok but the full screen view also doesn't work. Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 11, 2016 Author Report Share Posted February 11, 2016 update: not yet fixed in 1375 build Quote Link to comment Share on other sites More sharing options...
Murat Posted February 12, 2016 Report Share Posted February 12, 2016 Can you rebuild your DNG thumbs? Can't reproduce on your DNG files. If this not helps can you restart Daminion Server. Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 12, 2016 Author Report Share Posted February 12, 2016 Hi Murat, also the rebuild of the DNG didn't help. No problems with other programs (XnViewMP, PS) to handle the DNG files. As you can see, in the Import Dialog I can see the thumbnail but later in the imported item the thumbnail and all image data in the Properties Panel are missing. I'll send you a short video by email. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 12, 2016 Author Report Share Posted February 12, 2016 Import of the same file by rescan folders to a local catalog works Quote Link to comment Share on other sites More sharing options...
Murat Posted February 12, 2016 Report Share Posted February 12, 2016 What about restarting the server? Under what account your Daminion Server was launched? Can you also send me the server logs? Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 12, 2016 Author Report Share Posted February 12, 2016 Hello Murat. it didn't help to restart the server. The user has the rights of an admin and the server is running as LocalSystem. You get the log by email. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 13, 2016 Author Report Share Posted February 13, 2016 No problems to import the original CR2 files which were the source of the DNG file Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 19, 2016 Author Report Share Posted February 19, 2016 Hello, not yet working with 1384 build. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted February 19, 2016 Report Share Posted February 19, 2016 There is a bug with handling RAW images in the current Daminion 4.5 beta versions. A bug fix will be ready soon. Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 23, 2016 Author Report Share Posted February 23, 2016 Hello, sorry but it's still not working with the 1385 build. I removed the DNG from the catalog and imported them by Rescan Folders. No other result as before with the server catalog. It's working with a local standalone catalog. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted February 25, 2016 Report Share Posted February 25, 2016 You are right. Thanks! We forgot to include fixed files into this build. Should work in the next build (is building now...) Quote Link to comment Share on other sites More sharing options...
Uwe Posted February 25, 2016 Author Report Share Posted February 25, 2016 Hello Murat, it's working now in build 1388. Thanks. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
