exterminador Posted May 21, 2015 Report Share Posted May 21, 2015 Hi there, I was wondering if it is possible to rename label tags on Daminion's client interface? Let me explain, for instance, for some reason I use the "Comments" field to save dates in the format '2015-05-20', that helps me to do some other tasks. I would like to see in the Properties Panel the label "Some Date" instead of "Comments", would it be possible perhaps modifying a resource file or something? I can create a new custom field but I think that would add unnecesary complexity to my database as I won't use the Comments field for anything else. Also, I don't mind the field in the database to continue being "Comments", with the label being what I need it would be perfect. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
Murat Posted May 21, 2015 Report Share Posted May 21, 2015 You can try to do this by editing PicaJet.Daminion.Common.Localization.resources.dll file. But it will be replaced by new program updates Quote Link to comment Share on other sites More sharing options...
exterminador Posted May 23, 2015 Author Report Share Posted May 23, 2015 You can try to do this by editing PicaJet.Daminion.Common.Localization.resources.dll file. But it will be replaced by new program updates Thanks Murat! Will try that. Perhaps would it be possible to expose the resource files in .resx files instead of dll files? I'm not sure if it would be helpful for other users or it's just me :) Thanks again! Quote Link to comment Share on other sites More sharing options...
Murat Posted May 24, 2015 Report Share Posted May 24, 2015 resx files should be compiled to dll files. Quote Link to comment Share on other sites More sharing options...
