rene Posted December 5, 2014 Report Share Posted December 5, 2014 Hey Murat, getting this error on some computers when connecting.Even After upgrading! This Issue occurs on two Laptop Computers running Windows 7. My Computer running Windows 8 as well as the Server both can work with the catalog. ************** Ausnahmetext ************** System.IO.InvalidDataException: Error creating indexed tag value. Server returns id=:-1 bei PicaJet.Daminion.ClientCommon.CatalogMetadataManager.CreateIndexedTagValue(IIndexedTag indexedTag, IIndexedTagValue parentValue, IIndexedTagValue siblingValue, Object value, Boolean below, Boolean isGroup) in c:\DaminionAuto\Code\ClientCommon\Classes\CatalogMetadataManager.cs:Zeile 1743. bei PicaJet.Daminion.ClientCommon.CatalogMetadataManager.CreateIndexedTagValue(IIndexedTag indexedTag, IIndexedTagValue parentValue, Object value) in c:\DaminionAuto\Code\ClientCommon\Classes\CatalogMetadataManager.cs:Zeile 1710. bei PicaJet.Daminion.ClientCommon.CatalogViewPresenter.NavigatorOnOnChange(Object sender, EventArgs eventArgs) in c:\DaminionAuto\Code\ClientCommon\Presenters\CatalogViewPresenter.cs:Zeile 239. bei System.EventHandler`1.Invoke(Object sender, TEventArgs e) bei PicaJet.Daminion.ClientCommon.BookNavigator.DoChange() in c:\DaminionAuto\Code\ClientCommon\Classes\BookNavigator.cs:Zeile 791. bei PicaJet.Daminion.ClientCommon.BookNavigator.SetNewActiveBook(Object sender, MainThreadJobEventArgs args) in c:\DaminionAuto\Code\ClientCommon\Classes\BookNavigator.cs:Zeile 729. bei WinPicaJet.MainForm.DoMainThreadJobSync(Object sender, MainThreadJobDelegate job, MainThreadJobEventArgs args) in c:\DaminionAuto\Code\WinPicaJet\MainForm.cs:Zeile 1676. ************** Geladene Assemblys ************** mscorlib Assembly-Version: 2.0.0.0. Win32-Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400). CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll. ---------------------------------------- Daminion Assembly-Version: 3.5.0.1128. Quote Link to comment Share on other sites More sharing options...
rene Posted December 5, 2014 Author Report Share Posted December 5, 2014 Hey Murat, please find the Error Report I sent here as well. <?xml version="1.0" encoding="utf-8"?> <ErrorReport xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" ErrorDateTime="2014-12-05T16:27:42.078968+01:00" FeedbackEmail="[email protected]"> <ErrorInformation> <ErrorType>NullReferenceException</ErrorType> <ErrorMessage>Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.</ErrorMessage> <ErrorStack> bei PicaJet.Daminion.ClientCommon.CatalogView.get_ControlledVocabularySecurity() in c:\DaminionAuto\Code\ClientCommon\Classes\CatalogView.cs:Zeile 179. bei PicaJet.Daminion.ClientCommon.FullItemDataPresenter.SetupView(IList`1 mediaFormats) in c:\DaminionAuto\Code\ClientCommon\Presenters\FullItemDataPresenter.cs:Zeile 1237. bei PicaJet.Daminion.ClientCommon.FullItemDataPresenter.ShowItem(IMediaItem item) in c:\DaminionAuto\Code\ClientCommon\Presenters\FullItemDataPresenter.cs:Zeile 1753. bei PicaJet.Daminion.ClientCommon.FullItemDataPresenter.GetItemAndShow(IMediaItem item, Int32 selectIndex) in c:\DaminionAuto\Code\ClientCommon\Presenters\FullItemDataPresenter.cs:Zeile 1729. bei PicaJet.Daminion.ClientCommon.FullItemDataPresenter.OnAnswer(Object sender, TwoValuesEventArgs`2 e) in c:\DaminionAuto\Code\ClientCommon\Presenters\FullItemDataPresenter.cs:Zeile 1679. bei PicaJet.Daminion.ClientCommon.MediaItemsManager.GetItemReceivedAsync(Object sender, MediaItemsReceivedEventArgs e) in c:\DaminionAuto\Code\ClientCommon\Classes\MediaItemsManager.cs:Zeile 2856. bei PicaJet.Daminion.ClientCommon.MediaItemsManager.GetPageThreadEndExecute(Object sender, Boolean complete) in c:\DaminionAuto\Code\ClientCommon\Classes\MediaItemsManager.cs:Zeile 4085. </ErrorStack> </ErrorInformation> <ExecutingAssembly>PicaJet.Daminion.GUIComponents, Version=3.5.0.1128, Culture=neutral, PublicKeyToken=79327cc3eae946b6</ExecutingAssembly> <Application>Daminion Software Daminion 3.5.0.1128</Application> <CallingAssembly>PicaJet.Daminion.GUIComponents, Version=3.5.0.1128, Culture=neutral, PublicKeyToken=79327cc3eae946b6</CallingAssembly> <Comment /> Quote Link to comment Share on other sites More sharing options...
rene Posted December 6, 2014 Author Report Share Posted December 6, 2014 Any Idea what I can do here? Quote Link to comment Share on other sites More sharing options...
Murat Posted December 9, 2014 Report Share Posted December 9, 2014 Can you reproduce this issue and send me the server logs? Quote Link to comment Share on other sites More sharing options...
rene Posted December 10, 2014 Author Report Share Posted December 10, 2014 Hey Murat, yes I'm getting this error a lot! Sometime even on the Server machine while opening the Admin Panel! I will upload the Server logs later need to start one of the other laptops. Quote Link to comment Share on other sites More sharing options...
