franky68 Posted November 12, 2011 Report Share Posted November 12, 2011 Hello, I imported a bunch of images into the shared catalog. Now I was moving tags - I queried "Keywords/People/Family/Wife", hit CTRL-A to select them all and dragged the images to "People/Family/Wife" and then removed "Keywords/People/Family/Wife" from the selected images. This step has been repeated for several keywords/people. Now when I select a random image Daminion crashes and brings up the windows error report. This is repeatable with every image I select and the images are physically intact so I can load them in other applications without issues. The logfiles (client) seem pretty uneventfull: 2011-11-12 01:34:09,640 [8] DEBUG PicaJet.Daminion.Service.Client.WCF.Command.PrecalculateQueryResultCommand [(null)] Start : PicaJet.Daminion.Service.Client.WCF.Command.PrecalculateQueryResultCommand 2011-11-12 01:34:09,656 [8] DEBUG PicaJet.Daminion.Service.Client.WCF.Command.PrecalculateQueryResultCommand [(null)] End : PicaJet.Daminion.Service.Client.WCF.Command.PrecalculateQueryResultCommand This happens on the laptop and the desktop (server). Quote Link to comment Share on other sites More sharing options...
Murat Posted November 12, 2011 Report Share Posted November 12, 2011 Does autosync feature was turned on? If the problem is occurred on a shared catalog, then I need the server logs. Could you please try to reproduce the issue, then locate the log folder on the Server PC and send me it? Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 12, 2011 Author Report Share Posted November 12, 2011 Hello, how do I turn the autosync feature off when working with shared catalogs? In the standalone I need to quickly hit the "pause" button which is only available when the sync already started. In client/server I dont get that button. And no, I can not reproduce the issue since its permanent. Currently I can not work with Daminion since it crashes when I try to select an image. Ill send you the serverlogs. Quote Link to comment Share on other sites More sharing options...
Murat Posted November 12, 2011 Report Share Posted November 12, 2011 how do I turn the autosync feature off when working with shared catalogs? In the standalone I need to quickly hit the "pause" button which is only available when the sync already started. In client/server I dont get that button. Sorry, I forgot this. This feature is almost (but no yet) finished for the server version. And no, I can not reproduce the issue since its permanent. Currently I can not work with Daminion since it crashes when I try to select an image. Ill send you the serverlogs. Yes, please. To Valery: the log file contains the row: DE: "Tabellenname »image« mehrmals angegeben" EN: "Table name "image" more than once" ERROR: 42712 Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 12, 2011 Author Report Share Posted November 12, 2011 Yes, please. They should already be in your inbox - aint they? Quote Link to comment Share on other sites More sharing options...
Murat Posted November 12, 2011 Report Share Posted November 12, 2011 Got it, thanks a lot! Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 13, 2011 Author Report Share Posted November 13, 2011 Now this is strange. Today I can work with the laptop (where it started) while the problem persists on the Desktop. Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 14, 2011 Author Report Share Posted November 14, 2011 Ok, now the desktop is back again too. As said, the previous crashes happened all the time while it was and the desktop was not rebooted or anything since then. Could it be that the server crashes the clients if its overloaded? I imported quite a few images and changed tags on several thousand of them. Quote Link to comment Share on other sites More sharing options...
Murat Posted November 14, 2011 Report Share Posted November 14, 2011 It's a bit hard to reproduce the issue based on the log file. It will be very helpful if you describe me steps preceding to appearing this error (when the bug will appears in the future). Can you send me your settings folder: C:\Users\Frank\AppData\Roaming\Daminion Software\Daminion\1.0 Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 14, 2011 Author Report Share Posted November 14, 2011 Please see post #1 for a description of steps. Quote Link to comment Share on other sites More sharing options...
Murat Posted November 14, 2011 Report Share Posted November 14, 2011 Yes, I read it but unable to reproduce the error. Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 14, 2011 Author Report Share Posted November 14, 2011 Well, thats all I did... I imported roughly 10.000 images (yes, *after* double checking that I have backups *g) and changed the tags from keyword/person to person. I would estimate this about 20.000 keyword delete/add processes. As said, my guess is that the server had trouble with that number of actions and made the clients crash somehow. Unfortunately I couldn't check if the server was still busy since there is no idication. Quote Link to comment Share on other sites More sharing options...
Murat Posted November 14, 2011 Report Share Posted November 14, 2011 the server was still busy since there is no idication. 449 build supports the indication of the remote syncing: Daminion Server 0.8.7.449 Daminion Client/Standalone 0.8.7.449 Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 14, 2011 Author Report Share Posted November 14, 2011 Hmm.... I upgraded to that version and now the desktop shows 8535 images to sync... I didn't make any changes since saturday. Shouldn't those changes already be finished syncing? Quote Link to comment Share on other sites More sharing options...
Murat Posted November 14, 2011 Report Share Posted November 14, 2011 Hmm.... I upgraded to that version and now the desktop shows 8535 images to sync... I didn't make any changes since saturday. Shouldn't those changes already be finished syncing? The previous Daminion Server didn't display 'unsynced' number even if the background process was active on the server side. So the number might include changes made early than Saturday. Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 14, 2011 Author Report Share Posted November 14, 2011 What I meant was that the Server is running all the time. So whatever there was to sync should be written by now. Its not like I stopped the server or switched off the computer at all. So I am wondering that Daminion things there is still unsynced data. Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 14, 2011 Author Report Share Posted November 14, 2011 Ok, I went really brave and unpaused the sync (which I paused right as I launched the new version and noticed the number). After waiting for about 15 minutes the little wheel kept on spinning but the number of files still stalled at 8535 and didn't go down. Modifying files increased the number but there is no chance to make it go down. Pausing and unpausing the sync does not help. Btw. is it desired behaviour that the sync process can only be unpaused from the computer that paused it? Quote Link to comment Share on other sites More sharing options...
Murat Posted November 15, 2011 Report Share Posted November 15, 2011 Modifying files increased the number but there is no chance to make it go down. Pausing and unpausing the sync does not help. Please wait for some time after clicking on the Start(Unpause) button. Btw. is it desired behaviour that the sync process can only be unpaused from the computer that paused it? This can be unpaused from any computer where the shared catalog is opened. Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 15, 2011 Author Report Share Posted November 15, 2011 Please wait for some time after clicking on the Start(Unpause) button. As stated, I already waited for (far) more than 15 minutes and right now the sync process in unpaused for almost 30 minutes and its still at 8537. Unfortunately I can not query for unsynced images so see what constitutes this really high number... This can be unpaused from any computer where the shared catalog is opened. Now I can but I could swear this wasn't the case yesterday. I had it paused from the desktop and was not able to unpause from the laptop. However this now works and I can not reproduce it - maybe there was some other problem. Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 15, 2011 Author Report Share Posted November 15, 2011 Maybe I am totally misinterpreting something but the "synchronize" table in the database shows 265 entries with a "timestamp" of 2011/10/21 and an empty value in "processed". All others are 2011/11/11 and "f". Another observation is that I have up to 16 sync-entries for a single mediaitem. This looks like a lot of redundant write accesses ;) Quote Link to comment Share on other sites More sharing options...
Murat Posted November 15, 2011 Report Share Posted November 15, 2011 Another observation is that I have up to 16 sync-entries for a single mediaitem. This looks like a lot of redundant write accesses ;) Each entry is related to the item's properties (tags) but not to the files so there are no redundant accesses Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 15, 2011 Author Report Share Posted November 15, 2011 Each entry is related to the item's properties (tags) but not to the files so there are no redundant accesses Duhh.... silly me! Of course - there are 23.688 enties in total but only 8.537 unique mediaitems id's. This would meet my estimation of total changes I made to the images - which would mean that they haven't been synced so far at all. Any idea what I could do to get them synced? If I truncate the synchronize table is there any chance to force a full sync at a later time? Btw. it would be handy to have a saved search (like last import) which shows the images that are unsynced. Quote Link to comment Share on other sites More sharing options...
franky68 Posted November 15, 2011 Author Report Share Posted November 15, 2011 This can be unpaused from any computer where the shared catalog is opened. Ok right now I can not pause/unpause the sync from my laptop - but I need to go to the desktop (which has the client running too) to do either. Apart from that I have full access from the laptop. Quote Link to comment Share on other sites More sharing options...
franky68 Posted December 6, 2011 Author Report Share Posted December 6, 2011 I installed the current build (0.8.8) a few minutes ago and it seems the queue finally gets processed. Its number just dropped below 8000. I will report when its really at 0. If this will happen (without breaking too many images) I can even try the new version :) Quote Link to comment Share on other sites More sharing options...
franky68 Posted December 7, 2011 Author Report Share Posted December 7, 2011 Yupp, as I came back home about 3 hours later the sync counter was down to 24. Those 24 were images that I deleted from the filesystem but not on Daminion so I will forgive Daminion for not beeing able to sync them ;) However Daminion counted down like 24, 8, 1, 0 and started over with 24 again and this went on until I manually deleted the images from the catalog. I think it would be better if Daminion would stop the sync process once it finished *trying* to sync all images and raise an error dialog if there were errors. Quote Link to comment Share on other sites More sharing options...
