WilfriedB Posted August 7, 2014 Report Share Posted August 7, 2014 As announced, the latest build should be 1064, but I found only 1063 in the drop box. Build 1063 throws an exception each time, I click a menu item: System.NullReferenceException: Object reference not set to an instance of an object. at PicaJet.Daminion.ClientCommon.PicaJetEnginePresenter.ItemGroupAccessToChilds(Object sender, MenuEnableActionsEventArgs e) in c:\DaminionAuto\Code\ClientCommon\Presenters\PicaJetEnginePresenterActions.cs:line 3546 at PicaJet.Daminion.ClientCommon.ActionCollection.ExternalAccessToChild() in c:\DaminionAuto\Code\ClientCommon\Classes\ActionGroup.cs:line 183 at PicaJet.Daminion.GUIComponents.ContextMenuGenerator.StripMenuActivate(Object sender, EventArgs e) in c:\DaminionAuto\Code\GUIComponents\Classes\ContextMenuGenerator.cs:line 452 at System.Windows.Forms.MenuStrip.OnMenuActivate(EventArgs e) at System.Windows.Forms.MenuStrip.set_KeyboardActive(Boolean value) at System.Windows.Forms.MenuStrip.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- Quote Link to comment Share on other sites More sharing options...
Murat Posted August 7, 2014 Report Share Posted August 7, 2014 Sorry. I paused the Dropbox syncyng. The 1063 build was for internal testing. Please use the 1064 instead (on the way) Quote Link to comment Share on other sites More sharing options...
