[919] Color management for RAW files broken again ...
_noel_
Could you please check whether your Color Management settings weren't reset after the latest update.
I've checked them ... I've resetted them ... I did a reboot ... nothing helps
If CM is enabled for thumbnails and fullscreen view:
- NEFs are not OK both in thumbnail view and fullscreen view
- JPGs are not OK in thumbnail view but are OK for fullscreen view
hopefully you can solve this problem soon ... it did work with 911 ...
Regards
Eberhard
Just in case, can you send me a sample NEF file?
Does it help if you'll replace move these files?
c:\Program Files (x86)\Daminion Software\Daminion\MediaProcessors\ImageProcessor\iecore.dll
c:\Program Files (x86)\Daminion Software\Daminion\MediaProcessors\ImageProcessor\ielib32.dll
from the Daminion 911 folder to Daminion 919 folder?
Sorry Murat,
Probably my mistake :blush:
I did a clean uninstall, deleted all old versions of daminion, installed 919 fresh, refreshed the thumbs and reread the images, now everthing seemes to work ok ... the CM works for thumbs and for fullscreen view ... :good2:
I will test again with a new and fresh database, but I think my error was a false alarm.
Regards
Eberhard
