Sulawesi_Girl Posted October 6, 2011 Report Share Posted October 6, 2011 When I have a large number (meaning more than 10-15) of files selected, the properties panel takes a long time to show the files' properties. Sometimes it persists is saying "no files selected". Is that normal? And also, my computer has a screen resolution of 1024x600... When I try to customize the catalog tags shown on the left panel, the Customize pop-up has the bottom cut off. As in, I can't see the "okay"/"cancel" (or whatever is down there :P ). No matter how I resize it, I still can't see that part. Is that related to my screen size? (I tried to link to a screenshot; we'll see if it works properly) Quote Link to comment Share on other sites More sharing options...
Murat Posted October 7, 2011 Report Share Posted October 7, 2011 When I have a large number (meaning more than 10-15) of files selected, the properties panel takes a long time to show the files' properties. Sometimes it persists is saying "no files selected". Is that normal? Does the "no files selected" message disappears after some time? And also, my computer has a screen resolution of 1024x600... Thanks for the screenshot! Yes, I confirm that the problem occurs when vertical resolution is 600px. Will be fixed. Quote Link to comment Share on other sites More sharing options...
Sulawesi_Girl Posted October 7, 2011 Author Report Share Posted October 7, 2011 Yes, sometimes the "no files selected" message disappears, and the files' properties appear. But this takes quite a while, and sometimes doesn't happen at all, if there are too many files selected. Quote Link to comment Share on other sites More sharing options...
Murat Posted October 7, 2011 Report Share Posted October 7, 2011 What's your PC configuration? I guess it's due to the low performance of the Daminion for this action. Quote Link to comment Share on other sites More sharing options...
Sulawesi_Girl Posted October 7, 2011 Author Report Share Posted October 7, 2011 Toshiba NB305 Windows 7 Professional 32-bit Intel Atom CPU N450 @1.66GHz 1.00 GB ram Yeah, you're probably right. I'm becoming accustomed to slow performance on my computer for many resource-intensive programs :P Quote Link to comment Share on other sites More sharing options...
pgrondin Posted October 8, 2011 Report Share Posted October 8, 2011 I have also had the "No files Selected" problem appear on my system. I can't use hardware as an excuse. AUS Motherboard M4A89GTD-PRO/USB3 AMD 890GX SB850 AMD Phenom II X6 1090T 3.2 Ghz 8 GB DDR3 -1600 ATI HD-5770 Graphocs card WD Caviar Black 1.5 GB WD Green 2 GB I think it may be a delay that results when you apply a tag to a large number of files, and then, while those files are being updated, in the background, you try to select and tag more files. If this is the cause, the Synced box would be showing sync in progress. You may be able to use the new Feature in version 0.8.6 that allows you to pause file sync till you are done tagging for a while. 1 Quote Link to comment Share on other sites More sharing options...
rolo13 Posted October 28, 2011 Report Share Posted October 28, 2011 In reply to Sulawesi_Girl I think your Tosh is being a bit stretched to run W7 professional and your software on 1gb ram. If you could upgrade to 2gb it would help all round imop, it certainly did for my Asus 900. I appreciate it's all down to circumstances.... Quote Link to comment Share on other sites More sharing options...
