Thomas Posted September 30, 2013 Report Share Posted September 30, 2013 Hi everybody, after importing some 27k jpg files and using excessively hierarchical keywords (still not being an expert) nearly everything works fine for me with Daminion. However, in some cases (about 80 jpg files) a cannot explain the following phenomenon: Tags are not shown in Daminion's file properties panel (please see right-hand side of the attached file) even though the tags are indeed associated with the jpg files as shown by Daminion's "show all tags" option and as I verified using exiftool. Furthermore, there seems to be some random behaviour: When I delete the folders containing those 80 files and re-import the folders, for some of those 80 files the tags are shown while they are not shown any more for some other files. Maybe there is a problem in the tags structure within some of my files? If wanted and helpful, I can send a sample jpg file. Thanks for your help! Thomas Quote Link to comment Share on other sites More sharing options...
Uwe Posted September 30, 2013 Report Share Posted September 30, 2013 Hi Thomas, this is a known problem. I have the same one. Sometimes randomly the Title and Description Tags are empty fields in the Properties Panel even if they exist in the metadata of the file on disk like in your case. As long as this issue exists, I close the client and lunch the client again. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
Murat Posted September 30, 2013 Report Share Posted September 30, 2013 Do you work with local or shared catalog? Do the title and description appear again after restarting Daminion or reopening the catalog? This is a know bug (as Uwe noticed) and hunting season for this bug had been opened sometimes ago, but it's very hard to reproduce it and thus we didn't catch it yet. Quote Link to comment Share on other sites More sharing options...
Thomas Posted September 30, 2013 Author Report Share Posted September 30, 2013 Hi, Murat, hi, Uwe, sorry, it seems I missed the relevant discussion in the forum. The files whose tags are not shown remain the same after restarting Daminion or re-opening the catalog. The random behaviour only takes place when deleting files from the catalog and re-importing them. Btw, I'm using version 870 and a local catalog. Thanks for any information should the issue be solved. Daminion is a fvourite of mine. Regards, Thomas Quote Link to comment Share on other sites More sharing options...
Murat Posted October 2, 2013 Report Share Posted October 2, 2013 Hi Thomas, If the problem appears after restarting the Daminion - could you please send me your catalog file for analyzing? Quote Link to comment Share on other sites More sharing options...
