_noel_ Posted September 19, 2013 Report Share Posted September 19, 2013 Hello, Is it possible to have several Daminion versions installed in parallel on one PC, i.e. Daminion RC1 build 833, which works on one DB and build 875, which works on a test DB? Regards Eberhard Quote Link to comment Share on other sites More sharing options...
Murat Posted September 19, 2013 Report Share Posted September 19, 2013 Is it possible to have several Daminion versions installed in parallel on one PC, i.e. Daminion RC1 build 833, which works on one DB and build 875, which works on a test DB? Nope. But it's possible to have installed 2 different PostgreSQL versions, and connect them from Daminion Server using different ports (for ex: 5432 and 5433). You can work with one catalog at the same time. The active catalog (database) can be selected from the Admin panel. We are working now under the Daminion Server version that allows to open and work with multiple catalogs... Quote Link to comment Share on other sites More sharing options...
rene Posted September 19, 2013 Report Share Posted September 19, 2013 It would be awesome to be able to use more than One catalog in the network at once. There could be one catalouge for Docments, one for music, one for video and one for photos Quote Link to comment Share on other sites More sharing options...
_noel_ Posted September 19, 2013 Author Report Share Posted September 19, 2013 Nope. But it's possible to have installed 2 different PostgreSQL versions, and connect them from Daminion Server using different ports (for ex: 5432 and 5433). You can work with one catalog at the same time. The active catalog (database) can be selected from the Admin panel. We are working now under the Daminion Server version that allows to open and work with multiple catalogs... Thank you for your answer. I'm sorry, I've posted into the wrong forum: the post should have been posted into the Daminion "standalone" forum :-( I will do a new post ... Regards Eberhard Quote Link to comment Share on other sites More sharing options...
Murat Posted September 20, 2013 Report Share Posted September 20, 2013 Thank you for your answer. I'm sorry, I've posted into the wrong forum: the post should have been posted into the Daminion "standalone" forum :-( I will do a new post ... I didn't test it, but you can install Daminion 833, then copy it's folder to a new location. Then install Daminion 875. But I didn't test this scenario and don't know whether 833 version works in this case. There are might be some issues related to the concurrent access to the same settings. So I don't recommend you to keep 2 different versions of the Daminion Standalone version. Quote Link to comment Share on other sites More sharing options...
