pgrondin Posted August 30, 2011 Report Share Posted August 30, 2011 I have a number of photos which I processed in Capture NX2 to fix some colour balance issues. The edited photos that are supposed to be in portrait orientation are shown in Daminion thumbnails, and in full screen view in Landscape orientation. The Image Properties window shows the Proportion as "Vertical". When I originally loaded these images prior to Capture NX2 editing, they displayed correctly. When I view the edited images in Irfanview, or ViewNX the orientation displays correctly. If I recall correctly, when I edited the images in Capture NX2 ( on another computer ), I just copied the edited images back over the original files I am using to test Daminion. I don't remember what I did to get the thumbnails to update. I may have deleted the files from the catalogue and re-added them. When I Right Click on an image, and select "Actions / Rotate", what does Daminion do? Does it write anything to the image file, or is it just a flag in the catalog? I will send you one of these files. Peter Quote Link to comment Share on other sites More sharing options...
franky68 Posted August 30, 2011 Report Share Posted August 30, 2011 Hello Peter, I tried and I can reproduce this. Here is what I did: 1. I imported a bunch of NEF images into Daminion 2. Opened one of them which is in portrait into CNX2 and adjusted the white balance 3. Deleted that image from Daminion and re-imported it 4. Everything was fine but: If I use "update thumbnail" in step 3 instead of deleting and re-importing the image in Daminion is incorrectly shown in landscape. I did a few more tests and rotated a couple of images in CNX and used: a. With check-in/-out b. Delete and re-import c. Update thumbnail to update them in Daminion and all of them are displayed correct. So it seems the problem only occurs if CNX updates the image without modifying the orientation and the thumbnail is updated in Daminion. I could imagion that this problem will be solved once Daminion starts to detect metadata changes. This thread (https://daminion.net/user-forum/index.php?/topic/11-nikon-nef-format/) holds some more discussion regarding NEF images and image rotation if youre interested. Regarding your question what rotation inside Daminion does. This is kinda interesting I don't see any changes in Windows explorer nor CNX/VNX but the filedate is updated so Daminion must write something into the files. So I checked: It seems that Daminion does not make any functional changes to the image but it updates the modification date and also slightly modificates the header with empty lines so the offsets for the image data are different. Since there is no actual change to the image itself nor to its data I would rather have the modification date not be updated. This seems more correct and also would eliminate the write-access. Since write operations always bear some risk I'd rather have them limited to necessary operations. Quote Link to comment Share on other sites More sharing options...
pgrondin Posted August 31, 2011 Author Report Share Posted August 31, 2011 Thanks Franky68. I see from your other thread, that you have been chasing this one for some time. The revised work-flow you suggest should minimize the problem with Daminion, as long as I am consistent. Thanks Peter Quote Link to comment Share on other sites More sharing options...
Murat Posted September 4, 2011 Report Share Posted September 4, 2011 The problem with the wrong image rotation is a know bug: the Update Thumbnail function is not use the Orientation tag (changed by CaptureNX or any other image editing tool). I assume that CaptureNX changes the Orientation tag once you'll apply some adjustments. We'll fix it. When you rotate an image within Daminion (by Actions > Rotate ...) the program just updates the EXIF Orientation tag for those formats that support writing/updating metadata (JPEG, TIFF, PSD, PNG, NEF, CR2, DNG, etc.) But the actual image content doesn't changed. We rotate the actual image content only during the export. I am sorry for the delays with answers: I'll back from a short vacation trip soon. At the moment I have a limited access to the Internet. Quote Link to comment Share on other sites More sharing options...
pgrondin Posted September 4, 2011 Author Report Share Posted September 4, 2011 I'll back from a short vacation trip soon. At the moment I have a limited access to the Internet. The best boss I ever had told me he did not want to know where I went or how to contact me when I was on holidays. He wanted me rested when I came back. Relax! We can wait. Peter Quote Link to comment Share on other sites More sharing options...
Murat Posted September 4, 2011 Report Share Posted September 4, 2011 Thanks for the kind words. Sometimes it's difficult to understand where is the rest and where is the work :) Quote Link to comment Share on other sites More sharing options...
