JACalvo Posted May 8, 2013 Report Share Posted May 8, 2013 I'm trying to import a new folder into the database, which has 30.000 pictures already. The new operation will add another 15.000 When importing, it starts normally, the countdown starts and, at a random point, it stops. Don't get a crash, it simply stops the count, as if having a problem with a particular file, and gets there. If I try to cancel operation, nothing happens and control is never returned (program doesn't respond). If I wait, I'll wait forever. I suspect of .net as the source of this problem, but I couldn't isolate it. Anyway, I guess the first abrut exit from the application generated some problem into the database and that's the origin of next malfunctions. Can this be true? Is there any way to refresh database structure? (like compact it) I'm using windows 8 (x32) and Daminion standallone Quote Link to comment Share on other sites More sharing options...
Murat Posted May 9, 2013 Report Share Posted May 9, 2013 Could you please restart Daminion and check how many files were imported in addition to your previous 30k files? Please try to do the following: - Launch Daminion from the command link with -log_enable paparamer - Press Ctrl + F12 (this show you a folder with program settings) - Go back to the Daminion and try to import those 15k files again. Please let me know if the import process will continues. If you'll see an error or the program hangs again please send me the "1.0\Logs" folder from the Settings folders. Quote Link to comment Share on other sites More sharing options...
JACalvo Posted May 12, 2013 Author Report Share Posted May 12, 2013 Logs sent. Will wait for your diagnostic Quote Link to comment Share on other sites More sharing options...
Murat Posted May 13, 2013 Report Share Posted May 13, 2013 Can you try to import JA059750.dng or JA059747.dng images again? I've sent full paths to these images to your inbox. If the program hangs on these files, please email them to me for analyzing. Quote Link to comment Share on other sites More sharing options...
JACalvo Posted May 16, 2013 Author Report Share Posted May 16, 2013 Sorry, forget it. I started to have problems with more software than Daminion, so did a deep check and found some sectors in HDD are failing. So, not a Daminion problem, just the first program to have data on that sectors Quote Link to comment Share on other sites More sharing options...
Murat Posted May 16, 2013 Report Share Posted May 16, 2013 Ok. No problem. Thanks for the info! Quote Link to comment Share on other sites More sharing options...
