kalain Posted April 10, 2013 Report Share Posted April 10, 2013 Hi, When customising Preset Properties panel and change field order, like move to top Keyword field. User's sorting fields order is not memorized. If you close Properties panel and open it again all your customize field order has gone! Not very cool to do it again each time you open Preset Properties panel. Quote Link to comment Share on other sites More sharing options...
Sedat Posted April 10, 2013 Report Share Posted April 10, 2013 Same here and I already reported that 4 weeks ago without any response. But now, we are at least two. https://daminion.net/...ch__1#entry3493 Quote Link to comment Share on other sites More sharing options...
Murat Posted April 11, 2013 Report Share Posted April 11, 2013 Added to the bug-fixing list... Quote Link to comment Share on other sites More sharing options...
Murat Posted April 11, 2013 Report Share Posted April 11, 2013 Fixed in the 774 version. Quote Link to comment Share on other sites More sharing options...
kalain Posted April 12, 2013 Author Report Share Posted April 12, 2013 Fixed in the 774 version. Ok, Done for Properties fields but same problem for Catalog Tags fields. (build 777) All user field order is lost when closing Edit Preset window. Quote Link to comment Share on other sites More sharing options...
Sedat Posted April 12, 2013 Report Share Posted April 12, 2013 ...but same problem for Catalog Tags fields. (build 777) And in addition. The Settings are all doubled now. Quote Link to comment Share on other sites More sharing options...
kalain Posted April 12, 2013 Author Report Share Posted April 12, 2013 Strange because I have tried in French and English several time but didn't get your result. Only one choice each time!! Quote Link to comment Share on other sites More sharing options...
Sedat Posted April 12, 2013 Report Share Posted April 12, 2013 Yes it seems to be working in all languages except in German. Strange... Quote Link to comment Share on other sites More sharing options...
kalain Posted April 12, 2013 Author Report Share Posted April 12, 2013 Yes it seems to be working in all languages except in German. Strange... German works well in my computer!! Quote Link to comment Share on other sites More sharing options...
Sedat Posted April 12, 2013 Report Share Posted April 12, 2013 German works well in my computer!! Okay, then it must be something broken on my machine. Let' s see if a re-install might help... <edit> Okay, first I re-installed 777 with no change - still double entries. Then I installed 772 and this one is okay. Then I removed 772 with the windows setup and re-installed 777 and the double entries are back again... Quote Link to comment Share on other sites More sharing options...
Sedat Posted April 13, 2013 Report Share Posted April 13, 2013 The double entries are historie now. A complete hd image recovery did helped. Quote Link to comment Share on other sites More sharing options...
Murat Posted April 15, 2013 Report Share Posted April 15, 2013 Rawshooter, if this issue will appear again, please send me your settings file (Ctrl + F12 -> "1.0") Quote Link to comment Share on other sites More sharing options...
Sedat Posted April 15, 2013 Report Share Posted April 15, 2013 Yes I will do. Quote Link to comment Share on other sites More sharing options...
