Sedat Posted March 6, 2013 Report Share Posted March 6, 2013 (edited) The "copytags" window doesn´t show custom tag fields correctly. Only one of three are shown and after scrolling down the window, some weird distortion appears. The copy command for these custom fields doesn´t work either. It seems that only hierarchical type custom fields are working. edit: short update. I´ve created one more hierarchical type custom field and this is also be ignored. So only the first custom tag works. The rest will be ignored at all. Edited March 6, 2013 by Rawshooter Quote Link to comment Share on other sites More sharing options...
Murat Posted March 7, 2013 Report Share Posted March 7, 2013 Thanks for the info. It's definitely the bug. Quote Link to comment Share on other sites More sharing options...
Murat Posted March 7, 2013 Report Share Posted March 7, 2013 Fixed. Quote Link to comment Share on other sites More sharing options...
Sedat Posted March 7, 2013 Author Report Share Posted March 7, 2013 Fixed. wow! Quote Link to comment Share on other sites More sharing options...
