kalain Posted February 3, 2013 Report Share Posted February 3, 2013 Hi, When you have several input in your query like below, you can change and swap your choice between "AND" and "OR". That's agood point. Why not doing same thing with choice with a right click to select complementary choice like below. This would avoid to : - go back to Catalog Tags panel and change your choice - open advanced Query window. Quote Link to comment Share on other sites More sharing options...
Murat Posted February 4, 2013 Report Share Posted February 4, 2013 Thanks for the suggestion! Quote Link to comment Share on other sites More sharing options...
