phidias81 Posted March 14, 2013 Author Report Share Posted March 14, 2013 The file names will be very cumbersome in this case. Why not to add a server based script that will use some lightweight script to extract info from IPTC or even XMP of the uploaded images and display it on a more readable way along with your images, like Flickr, Fotki or other photo sharing web-sites do. In this case your descriptions will be Google and human readable. Clearly it would be much better to display it caption or meta description or meta keyword, etc. but since I'm not a developer I have no idea how to write the script :) For now I managed to change the filename with exiftool after a lot of reading, waiting for my photo gallery extension to support IPTC. If anybody needs it, this line is renaming the files adding country tag, city tag and keywords, separated by - exiftool -sep "-" "-filename<${city;}-${country-primarylocationname;}-${keywords;}_%f.%e" DIR change DIR with the path of the directory you want to rename. ALL the files in the directory will be renamed. Quote Link to comment Share on other sites More sharing options...
phidias81 Posted March 23, 2013 Author Report Share Posted March 23, 2013 This version add also people tags, change space with -,and skip empty fields exiftool -m -sep "-" "-filename<${city;tr/ /-/}-${country-primarylocationname;tr/ /-/}-${keywords;tr/ /-/}-${personinimage;tr/ /-/}_%f.%e" C:\Users\davide\Desktop\DIR Quote Link to comment Share on other sites More sharing options...
phidias81 Posted December 17, 2013 Author Report Share Posted December 17, 2013 After long time I've found two more small bugs. I have to say that I'm on the build 833, do they might have being fixed in the meanwhile. The first one is that if I slect a folder with several subfolders and many photos, in example 2000, only part of them are showed. The second one is when I select multiple photos, in example 20 or 50, it is not showing the properties panel on the right. I have to deselect one photo and reselect it again and the it's working. I have to say that is not happening constantly, it's just random. Quote Link to comment Share on other sites More sharing options...
phidias81 Posted December 18, 2013 Author Report Share Posted December 18, 2013 A new feature that would be really useful (I don't know if already planned for the future) is to group on request photos coming from the same origin, under the same icon, even if I have them in different folders. In example: I have a series of Raw photos. Only part of them has been developed in another folder. With a right click on the original Raw that has been developed, I can choose to open, copy, etc a particular format (I'm thinking of the e-book management system Calibri that has the same system), so that I can access the developed jpeg easily from the original Raw Quote Link to comment Share on other sites More sharing options...
Murat Posted December 18, 2013 Report Share Posted December 18, 2013 ...group on request photos coming from the same origin, under the same icon, even if I have them in different folders... Added your vote for this feature. I will be called Stacks. The first one is that if I slect a folder with several subfolders and many photos, in example 2000, only part of them are showed. By default all thumbails you received after a certain query are grouped into pages by 1000 thumbnails per page. But you can switched between pages. And you can change this limit in your program preferences. Quote Link to comment Share on other sites More sharing options...
