Razminka Posted July 13, 2011 Report Share Posted July 13, 2011 Maybe it's a stupid question, but I don't know how to do. Accidentally moved the mouse keyword in the Catalog Tags area. How to raise a higher level? root level? Quote Link to comment Share on other sites More sharing options...
Murat Posted July 13, 2011 Report Share Posted July 13, 2011 Any questions are welcome! You need to drag "Level2" to Level1's parent tag. Quote Link to comment Share on other sites More sharing options...
Razminka Posted July 13, 2011 Author Report Share Posted July 13, 2011 Maybe I'm wrong explained. Sorry for my english :unsure: I install Daminion to try. Imported images. I have a flat list of tags, without nested tags. When I click the mouse on the tags list I mistakenly moved the one inside the other. Now I have nested tags. How do I get back? Мурат, простите, возможно моего английского не хватит чтобы толково объяснить вопрос, но другим пользователям однозначно пригодится ваш ответ. В окне программы, где Catalog Tags -- Keywords. Был плоский одноуровневый список тегов. Мышкой случайно передвинула один внутрь другого. Пыталась исправить - обнаружила, что мышкой могу передвигать только между тегами, а поднять на самый верх, в корень - не могу. Меню правой кнопки мыши позволяет создавать вложенные уровни, но нигде я не нашла возможности переместить тег в иерархии на уровень вверх. Quote Link to comment Share on other sites More sharing options...
Murat Posted July 14, 2011 Report Share Posted July 14, 2011 Ann, thanks for your feedback! You are right, it's impossible to move a tag from x-level to zero-level. This is a bug, and I guess we'll fix it to the upcoming release version. I've emailed a copy of this message in Russian to your email. Please check it out. Quote Link to comment Share on other sites More sharing options...
Alexius Posted July 15, 2011 Report Share Posted July 15, 2011 Hello, Ann. We've fixed this issue. There are two ways to move a tag up by the hierarchy: 1. Just drag a tag to a new parent or into a Tag Name to move it to root. 2. You can use the context menu of the item "Move Out" to move it up by the hierarchy. These changes are available in a new Daminion version. Click on this direct link to download it. Quote Link to comment Share on other sites More sharing options...
Razminka Posted July 15, 2011 Author Report Share Posted July 15, 2011 Excellent. Thank you! Both ways work in 0.8.4 Quote Link to comment Share on other sites More sharing options...
