kalain Posted September 9, 2012 Report Share Posted September 9, 2012 Hi, I expected that Long / Lat / Altitude Image fields could be editable, in order to complete images which has no GPS data! (but taken in the same spot with others images with GPS infos) By now, there is 2 things : - Lat / Long / Altitude fields are not editable ! This means, if I want to change these datas I have to use another software. (Hum!) - When a picture has not GPS data recorded, Lat / Long / Alt fields are not displayed in Image properties panel ! So even if these GPS fields could be editable, I couldn't do it because an empty field is not displayed in properties field!!! This reflexion (problem) is also tru for any other field. May be, an extra option could be added in properties panel field, like below : All tagged fields (red point in this example) are displayed even if they are empty. Like this, if the tagged field is editable, user could complete and add infos in it. Regards Quote Link to comment Share on other sites More sharing options...
kalain Posted September 9, 2012 Author Report Share Posted September 9, 2012 Well, I expected that Lat/Long/Alt field would behave same as : - Creation datetime field : Possibility to modify and update several Lat/Long/Alt field when several pictures are selected. - Keyword field : Display all different Lat/Long/Alt values. This would help to assign a new Lat/Long/Alt value at selected images. This would be easier to make an average if all values are displayed. Regards Quote Link to comment Share on other sites More sharing options...
Murat Posted September 11, 2012 Report Share Posted September 11, 2012 Hi Alain, Thanks for the suggestion. You are right. We don't display empty readonly fields (tags) in the Properties panel. This is why GPS tags are not visible in your case. If we'll make them editable they will be visible on the right panel automatically. But we'd like return to this task during implementing a GPS stamping tool via integrated visual maps, like Google Maps. Quote Link to comment Share on other sites More sharing options...
