Uwe Posted August 26, 2012 Report Share Posted August 26, 2012 Hello, the sort by "Place" doens't work in any cases in the "List View" of the Thumbnail Window. You get: "no items match your search criteria". As long as "Sort by Place" is activ in the bottom line of the window you can't use "show all" and also the selection of the highest level in the Catalog Tags doesn't work. If you select a lower level in the Catalog Tags Window the sort by Place works. Regards, Uwe Quote Link to comment Share on other sites More sharing options...
