Uwe Posted April 29, 2024 Report Share Posted April 29, 2024 Hello, after importing GPX files, I realised that their FileCreateDate is wrong. I corrected the data using ‘BulkFileChanger’ and then wanted to correct the Daminion DB using the ‘Read Tags from file’ action. Unfortunately the action ‘Read Tags from file’ does not read the corrected file system data of the GPX file. You have to remove the GPX file from the catalogue and import it again. regards, Uwe Quote Link to comment Share on other sites More sharing options...
