kalain Posted July 23, 2012 Report Posted July 23, 2012 Hi, Double click on a thumbnail, Now in this opened window (Full screen) - select 100% zoom - drag your image up to the left (or any) corner. Now, select : "Fit Image" zoom Image doesn't fit correctly to the screen. You need to click in order to center and fit correctly image to the screen. Regards Quote
