GMcDowellJr Posted June 5, 2012 Report Share Posted June 5, 2012 I am looking for a way to assign project names to our images. We have the images in their own folders by project but the naming convention has changed over the years and there is a desire NOT to go back and standardize them (something about inDesign linking). At any rate there appears to be a Project parameter but I can't figure out how to assign it to my images. If I customize the Catalog Tags dialog I can get the Project property, under Description, to appear in my list. I can create new Projects by right-clicking over the field and choosing Add new project. However, this parameter does not appear in the image properties dialog and I can't figure out how to assign it to my images (no amount of drag-n-drop seems to work). Is this a "yet to be implemented" property or am I just missing something? How else might I achieve a similar outcome? Quote Link to comment Share on other sites More sharing options...
Murat Posted June 10, 2012 Report Share Posted June 10, 2012 Coild you please check the issue with this minor update: https://daminion.net/files/DaminionSetup-0.9.0.543.exe. Please consider to create your project hierarchy under the Categories tag, because Project and Client tags are not mapped to the metadata. Quote Link to comment Share on other sites More sharing options...
