exterminador Posted September 7, 2020 Report Share Posted September 7, 2020 Hi there, I just updated to 2225 and noticed color labels in the tag panel changed order. By reviewing, it seems to me queries are no longer using the sortorder column from the colorlabel_table. Instead, they appear to be sorted using the helpervalue column. Is it feasible to change it back? I initially used the sortorder to show the color labels in a way that made sense with the labels I gave to the colors. Now they appear scramble to me. Attaching a screenshot of how they appear to me. BTW, kudos on the update! 🙂 I updated also to PostgreSQL 11 and got a noticeable improvement in performance. Thanks! Best regards Quote Link to comment Share on other sites More sharing options...
