Posted
In Daminion there are three windows where you can customize displayed options (see below). Would it be possible in some future version to use only one window with three panes to customize and save displayed presets?
Why? I'm seriously considering Daminion as a very powerful pdf manager. Obviously, I need a different data set for pdfs (e.g. no shutter speed, etc.). I'd like to be able to select a custom preset name only in one menu.
Posted
If you need to save your user settings you can locate (via F12 key) and save the folder below:
C:\Users\[userName]\AppData\Roaming\Daminion Software\Daminion\1.0\SettingsCache
Posted
Actually what I meant is to make one Customize window with two columns instead of the two windows shown below. It would be possible then to save custom settings for both panes under one name.
-- M.
