exterminador Posted April 12, 2012 Report Share Posted April 12, 2012 Hi, I was wondering if there is a way to purge the Un-synced files list (or completely turn off metadata syncing). I relay on the file's modified date to do sorting outside Daminion so I prefer keeping metadata only on Daminion's database instead of writting it to the file. Regards Quote Link to comment Share on other sites More sharing options...
Murat Posted April 12, 2012 Report Share Posted April 12, 2012 There is no way to clear this list, you can only turn off the "Auto-Sync feature" from the Sync button menu. Once you'll turn it off, the sync icon will be crossed by red line: Quote Link to comment Share on other sites More sharing options...
dehiworld Posted April 28, 2012 Report Share Posted April 28, 2012 I have approx 6000 pictures in my catalog and I'm slowly working my way through updating keywords and locations. Some have needed to have their metadata updated. I have updated about 2/3rds of them. I now find that, after updating approx 160, the auto-sync just hangs on 162 and I can no longer update any metadata. Updating additional files achieves nothing but increase the no of files needed updating. I get a message that 1 or more files appear to be offline but I have no idea what this file may be. No files have been deleted. Quote Link to comment Share on other sites More sharing options...
Murat Posted April 29, 2012 Report Share Posted April 29, 2012 Could you please update your Daminion to 532 build and check the issue again. A list of Unsynced files can be located via Smart Tags... Quote Link to comment Share on other sites More sharing options...
