joran Posted June 7, 2011 Report Share Posted June 7, 2011 I installed the latest build (331) and I get an error message saying “Daminion DAM system for small teams has stopped working” (translated from Norwegian). The details (in Norwegian): Beskrivelse: Stopped working Problemsignatur: Navn på problemhendelse: CLR20r3 Problemsignatur 01: daminion.exe Problemsignatur 02: 0.8.2.331 Problemsignatur 03: 4de3c315 Problemsignatur 04: mscorlib Problemsignatur 05: 2.0.0.0 Problemsignatur 06: 4d4f14f6 Problemsignatur 07: 41bf Problemsignatur 08: a3 Problemsignatur 09: FBE0ZW2US0ALHHPIG1VZIXIRL2UWNMQS OS-versjon: 6.1.7601.2.1.0.768.3 ID for nasjonal innstilling: 1044 I use Windows 7 64 bit with 12 GB ram and Intel i7 prosessor. Jøran Toresen Quote Link to comment Share on other sites More sharing options...
joran Posted June 7, 2011 Author Report Share Posted June 7, 2011 Follow up I uninstalled Daminion using Control Panel. Installed build 331. And got this message at startup: "Last session was emergency shutdown. Do you wish open recent catalog?". I selected Cancel. Damion started. But I got the stopped working message when I tried to open my last Catalog. Then I tried to create a new Catalog and got this error message when I wanted to save the new catalog: "No object named 'LocalCatalogMediumManager' is defined: Cannot find definition for object [LocalCatalogMediumManager]. Jøran Toresen Quote Link to comment Share on other sites More sharing options...
Murat Posted June 7, 2011 Report Share Posted June 7, 2011 Please update your Daminion to 0.8.2 (333) version: - Fixed bug with AND/OR boolean operators - Fixed bug with wrong Folders presentation - Add link to Daminion Wiki (F1) - Fixed a few minor bugs Quote Link to comment Share on other sites More sharing options...
joran Posted June 7, 2011 Author Report Share Posted June 7, 2011 I can confirm that build 333 opens without problems on my PC. And the AND-OR bug is fixed. But there is another problem with AND-OR that I will describe in a new tread. Jøran Toresen Quote Link to comment Share on other sites More sharing options...
Murat Posted June 7, 2011 Report Share Posted June 7, 2011 Joran, Please share your problem, so we can fix it to the next build Murat Quote Link to comment Share on other sites More sharing options...
