Adobe DNG Converter not found?
mjungwirth
I have installed the Adobe DNG Converter 9.7.
The installed Path is "C:\Program Files (x86)\Adobe"
But Daminion can't find the raw-converter. I can convert all Images by Hand but not with the Import Option "Raw Dateien in DNG". This Option is disabled (gray).
Can i set the path of the converter in Daminion?
Can i see and log Information about the Problem?
I use Daminion (Server/Client) with Version 4.6 (1481)
lg
Mario Jungwirth
  • Upvote 1
