wabrou Posted March 22, 2016 Report Share Posted March 22, 2016 I'm a heavy Lightroom user for post-processing, and rely on it for my initial metadata assignments. I'm fairly certain I know the answer to this, but need to be sure I'm not missing something before moving on. By any chance, are Collection Tags being populated on Import from an IPTC field (or any common field!) that I'm just not catching? I'm not figuring so, but need to be sure. In the same vein, I notice that Category Tags are imported from the IPTC field "Other Categories" but the main/primary "Category" field is not being imported anywhere. Am I missing an Import here, by chance? ...Bill Quote Link to comment Share on other sites More sharing options...
Murat Posted March 23, 2016 Report Share Posted March 23, 2016 Hi Bill, Daminion's Collection tag is mapped to the below metadata fields: XMP:MWG:Collections (Read/Write) XMP:IViewExpressionMedia:CatalogSets (Read Only) XMP:IViewMediaPro:CatalogSets (Read Only) Categories tag is mapped to: XMP:Photoshop:SupplementalCategories (Read/Write) XMP:ACDSee:Categories (Read Only) IPTC:SupplementalCategory (Read Only) XMP:DC_Type (Read Only) IPTC IIM Category field was earmarked as deprecated already for IIM 4.1, it was not included into IPTC Core. So we don't use it. Instead you this field you can consider migrating to Subject Codes. More info about migrating from Category codes to Subject Codes please read this Guideline. All metadata mapping rules in Daminion: https://daminion.net/files/daminion-metadata-mapping-rules.pdf Quote Link to comment Share on other sites More sharing options...
wabrou Posted March 23, 2016 Author Report Share Posted March 23, 2016 Hi Murat- Thanks for this info, and thanks for the mapping PDF! One last question in this area. Are hierarchical keywords being flattened on import, or were they likely flattened when written to my image files in the first place (e.g., is that the standard practice)? I have a hierarchical keyword structure in Lightroom and replicated that structure in Daminion. But the keywords are being flattened on import. Many thanks, ...Bill Quote Link to comment Share on other sites More sharing options...
wabrou Posted March 23, 2016 Author Report Share Posted March 23, 2016 Scratch that last question. Figured out that if I actually TELL lightroom to write keywords as hierarchy, it does- and Daminion does import them that way. ...Bill Quote Link to comment Share on other sites More sharing options...
Murat Posted March 25, 2016 Report Share Posted March 25, 2016 Thanks for this info, and thanks for the mapping PDF! One last question in this area. Are hierarchical keywords being flattened on import, or were they likely flattened when written to my image files in the first place (e.g., is that the standard practice)? I have a hierarchical keyword structure in Lightroom and replicated that structure in Daminion. But the keywords are being flattened on import. This is probably because LR writes flattened keyword structure when saving keywords in addition to its hierarchical structure. Daminion can flatten keywords only when exporting (when an appropriate option is checked) You can also go to the Edit > Preferences > Reading Metadata settings and check the "Mark imported tags as unapproved" if you don't want to "damage" your existing tag structure by newly imported tags. Quote Link to comment Share on other sites More sharing options...
Murat Posted March 25, 2016 Report Share Posted March 25, 2016 Scratch that last question. Figured out that if I actually TELL lightroom to write keywords as hierarchy, it does- and Daminion does import them that way. Perhaps it also depends from LR's version. What LR version do you use? Quote Link to comment Share on other sites More sharing options...
wabrou Posted March 26, 2016 Author Report Share Posted March 26, 2016 Sorry Murat. I didn't even see this reply/question. I'm on the current version (I subscribe to their photography bundle for photoshop/lightroom so always on the latest release). ...Bill Quote Link to comment Share on other sites More sharing options...
