kalain Posted February 19, 2016 Report Share Posted February 19, 2016 Hi, When using F6 / rescan feature, it would be better to fully display folder path to rescan inside popup window rather to display it in popup window name. By now, when you have a long path name, you can't check what you are doing!! to display it inside popup window you can check what you are exactly doing. see a screen shot to illustrate. Quote Link to comment Share on other sites More sharing options...
Murat Posted February 19, 2016 Report Share Posted February 19, 2016 Thanks, Alain! Quote Link to comment Share on other sites More sharing options...
Murat Posted April 5, 2016 Report Share Posted April 5, 2016 Fixed in the latest builds Quote Link to comment Share on other sites More sharing options...
