1360 - installation ghostscript
Uwe
I marked the box to install ghostscript. But then I went back to unmark the box because I've already ghostscript installed for other applications. Independent from the unmarked box the installation procedure downloaded and installed ghostscript. This seems to be a bug in the installation procedure not to check once more the box of the ghostscript installation.
The aditional question is: Why not using the existing ghostscript installation and if daminion needs a newer release compared to the installed one, why to asking to update the existing ghostscript installation by Daminion?
