kalain Posted June 23, 2015 Report Share Posted June 23, 2015 Hi, In full view mode you can use '+' and '-' key for zoom in and zoom out. that's pretty good but this one can be improved a bit more. When you open a picture in full view mode : - zoom display used is a fit to window zoom. (Ok good). Let's say 42.6%. - you can use left and right arrow to browse pictures. Ok, good. Now, when you use '+' and '-' key to zoom in and zoom out you will browse 50, 66, 75%, 100% and when zoom back 75%, 66, 50, 33%. In these zoom values, when you use arrow key (left and right) you pan window. (ok, good) What could be improved here is when you zoom in and zoom out with '+' and '-' key to insert 'zoom to fit' value in zoom steps like : 75%, 66, 50, 42.6 (which is zoom to fit), 33% When you are on 'zoom to fit' value, left and right key are used to go previous or next items. (not any more used to pan window. There is nothing to pan in 'Zoom to fit'.) this would give a bit more power in zoom values when '+' and '-' keys are used. 1 Quote Link to comment Share on other sites More sharing options...
Sedat Posted June 24, 2015 Report Share Posted June 24, 2015 As an alternative you can always use the page up and page down keys to go to the next or previous item. Regardless which zoom value is set to. Does that maybe help? Quote Link to comment Share on other sites More sharing options...
